Spaced Repetition for Language Learning: The Science Behind Better Vocabulary Retention
You've probably heard that flashcards are effective for learning vocabulary. But not all flashcard methods are created equal. Spaced repetition—a technique that schedules reviews at increasing intervals—can dramatically improve how well you remember words. Here's how it works and why it's so powerful for language learning.
What is spaced repetition?
Spaced repetition (also called spaced retrieval or SRS—Spaced Repetition System) is a learning technique where you review information at gradually increasing intervals. Instead of cramming vocabulary once and forgetting it, you see words again right before you're about to forget them. This timing strengthens your memory each time.
The concept dates back to the 1880s, when German psychologist Hermann Ebbinghaus discovered the "forgetting curve"—the rate at which we forget information over time. Spaced repetition works against this curve by strategically timing reviews to reinforce memories before they fade.
How spaced repetition works
When you first learn a word, your memory of it is weak. If you review it the next day, you strengthen that memory. Wait too long, and you've forgotten it entirely—forcing you to relearn it from scratch. Spaced repetition finds the sweet spot: reviewing just before you forget.
Here's a typical pattern: You learn a new word today. You review it tomorrow (1 day). If you remember it, you review it again in 6 days. Then 12 days, then 24 days, and so on. Each successful review extends the interval, because your memory is getting stronger.
Why spaced repetition is so effective
Research shows that spaced repetition can improve long-term retention by 200-400% compared to massed practice (cramming). For language learners, this means:
- Better retention: Words stick in your long-term memory instead of disappearing after a few days
- Efficient studying: You spend time on words you're about to forget, not words you already know well
- Less frustration: You're not constantly relearning the same words over and over
- Faster progress: More words stay learned, so you can focus on learning new ones
Spaced repetition algorithms
Modern spaced repetition systems use algorithms to calculate optimal review timing. The most popular is the SM-2 algorithm (used by Anki), which adjusts intervals based on how well you remember each card. When you rate a card as "easy" or "hard," the algorithm adapts—easy cards get longer intervals, hard cards get shorter ones.
These algorithms track several factors:
- Repetition count: How many times you've successfully reviewed the card
- Ease factor: How difficult the card is for you personally
- Interval: Days until the next review
- Performance: Your recent success rate on the card
Using spaced repetition in language learning
Spaced repetition works best when combined with active recall—actually trying to remember the word before seeing the answer. This is why flashcards are so effective: you see the word in your target language, try to recall the translation, then flip to check.
For best results:
- Be honest with your ratings: If you didn't really remember it, don't mark it as "easy"
- Review consistently: Daily reviews work better than sporadic cramming
- Focus on context: Learn words in phrases or sentences, not isolation
- Combine with practice: Use spaced repetition for vocabulary, but also practice speaking and listening
How Speekeezy implements spaced repetition
Speekeezy uses a spaced repetition algorithm in its flashcard system. When you review flashcards, the app tracks how well you know each word and schedules future reviews accordingly. Words you know well appear less frequently, while words you're struggling with come up more often.
This means your flashcard practice is optimized automatically—you don't need to manually decide when to review each word. The app does the scheduling based on your performance, so you can focus on learning rather than managing your study schedule.
The bottom line
Spaced repetition isn't magic, but it's one of the most scientifically-backed methods for vocabulary retention. If you're serious about building a strong vocabulary in your target language, using a spaced repetition system will make your study time more effective. Combine it with conversation practice, and you'll see faster progress than with traditional study methods alone.
The key is consistency: a few minutes of spaced repetition practice each day will do more for your vocabulary than hours of cramming once a week. Start with a small set of words, build the habit, and let the algorithm handle the scheduling.
